Anything to note with either of your phones?
Storage mostly full? Using external storage?
I’ve not been able to replicate this yet.
Did your phone have about a week of uptime continously before this occurrence?
Storage only 30% full, nothing else of note that i can think of.
Yes, was probably a solid week of up time
Thanks for reporting this issue. We are hoping Beta2 (coming soon) will resolve it.
Hello so is Google wallet not working on all z model phones?
Google Wallet works as long as you’re able to install the Google Play system update and are on a certified build.
Google Wallet might work (have not checked), but Google Pay will certainly not work on current Android 13 Beta builds or any other uncertified build.
Google Wallet and Pay are the same core app in the background, just different skins.
I took Lwc726’s question as asking whether secured storage was broken on all Zirconia phones regardless of build, based on the period a few months back when only release 10.0.6 worked and the certified 10.0.13 and all 11 builds were failing tap-to-pay. If my assumption was correct in terms of the original question then the answer is that your phone needs to be certified with at least the Google Play system update installed, even if you don’t have the full security update.
But yes, none of the 12 or 13 builds released yet are certified, so tap to pay should not work on them yet, unless weird attempts are made and successful.
I have downloaded the Update apk file on my phone but I cannot install the update as I do not have the three dots in the top right corner of the updater on my phone.
I am running the 12.1 version.
How can I install this update?
Sorry for the trouble!
Can you screenshot what you see, and please also confirm whether you have the 2020x Serial 2e (Zirconia) or 2021x Serial 2e (Emerald)?
Android 14 is available now, [Public Beta] Android 14.0.1 for Teracube 2e 1st Batch (SN: 2020)
Android 15 is now available at Android 15.0.1 for Teracube 2e 1st Batch Zirconia (SN: 2020) or Android 15.0.1 for Teracube 2e 2nd Batch Emerald (SN: 2021) depending on your device.
