Archive
** Warning **
- Not for the faint-hearted. This is Beta software. If something goes wrong, you might lose your data and might have to re-flash factory Android (instructions at the bottom of this post).
- Read the notes before you install.
And we have reached 2nd Beta—many bug fixes, including Wifi calling and auto brightness.
What works
- Android 13 + Aug 2023 security update
- VoLTE, Vowifi, wifi, and Bluetooth have all been tested
- Upgrade from Android 10, 11, 12.1, 13-Beta1 have been tested in the lab
- Stable and even more smoother
Known issues/changes - do read before proceeding
- The build is not certified.
- Live Wallpapers not functioning.
Steps
- Emerald link (SN:2021)
- Zirconia 12.1 users - Read here first
- All other Zirconia users
- Goto Settings > System > Updater (or Teracube Updater)
Note: If the Updater closes or crashes, then try again. - Upgrade process will take a while.
- Reboot the phone after the updater says “Update installed”.
If you experience any errors/issues, you can flash the original factory firmware using the automated installer or SP Flash.
