[ Troubleshooting ] Notification Light Always Active
Known Issue
The LED should turn off if there are no notifications available at all - that is, if you pull down the tray and all you see are the toggle buttons and the text “No Notifications”. If there are any notifications there, the LED will blink slowly any time the screen is locked. Unfortunately, the option to disable the notification LED doesn’t seem to have an effect right now, but we plan to fix it in the next update for the 2e.
If the phone is unlocked, the LED should not blink. If the phone is plugged in to charge, the LED should be lit permanently.
I was having this issue and realized it is because of the charge reminder described here: Battery settings and functions
This may be the case for others that have set this up but don’t realize/remember it comes with a reminder, but no pop-up notification to tell you what the blink light is for.
Yeah - there is an existing discussion for the notification led behavior - with lots of feedback for us :slight_smile:.
