Note: There is a newer 11.0.4 update available now.
Archive
Note : This update is for the 1st batch of T2e (SN:2020)
** Warning **
Please backup your data before proceeding.
Check Known issues below before proceeding.
Here is our 1st stable and (Google) certified Android 11 for Teracube 2e (1st batch; SN 2020). Even more performance improvements and bug fixes over the Beta release. We are continuing to work on the next update.
What works
- Google Certified - so Google Pay, Netflix, Disney+ all work.
- Will work for all regions (US, Canada, UK, EU, Rest of the world)
- Bluetooth music and calling, NFC, WiFi, Cellular, VoLTE - all work
- Notification LED behavior fixed.
- Bluetooth range and music skipping issues should be fixed.
Known issues - What does not work yet
- FM does not work
- Hotspot
- Not a bug but more of an Android 11 feature. SIM cards canāt be disabled individually for Dual SIM setups.
- Performance is still being tuned. You may experience some slowdowns.
Steps
- Tap āInternal storageā and browse to Downloads or wherever you transferred/downloaded the update zip file.
- Select the file and continue the update process.
- It will take a while. The phone will power off and restart by itself. Donāt press power button.
If you experience any errors/issues, you can flash SW6 (original Android 10 firmware) using these instructions.
