Message from AT&T About My Phone Not Compatible?
We are already in the process of getting Teracube 2e certified for AT&T. Once that is complete, we will look into Teracube One as well.
Wonderful!
Thanks so much
Hi @Chris_Schafer - did you have an existing AT&T SIM or were you activating a new one?
Can others with AT&T confirm their experience?
From what I understand for the Teracube_One, as long as your SIM doesn’t move between the incompatible and compatible phones, they won’t lock your service.
If I were to move my SIM to something else and back, my account will be locked.
Since I’ve not moved our SIMs since we got the Teracube_One, we’re okay with service until the cut-off date.
My wife and I also have positively ancient Cricket SIMs, so who knows what that means in all of this.
A post was merged into an existing topic: Cricket wireless issue with Teracube 2e (Update: AT&T is working fine)
4 posts were split to a new topic: Teracube 2e RedPocket AT&T setup
Sound like you should have been doing both phone certifications at the same time.
So will the Teracube 1 get certified with AT&T so that we can update the IMEI number with AT&T and get VoWiFi/VoLTE/HD Voice.
That’s the plan. Hopefully it happens soon for everyone :slight_smile:
We will look into T1 certification after Teracube 2e gets certified. The process is stretched out and expensive - so we want to finish 1 phone first which was already underway.
Any news about certification? I’d like to keep the same phone and not have to buy a new one
We have been working with AT&T for T1 as well. Its a slow process - waiting to hear back from them on the latest communication.
Following this topic. I also got this notification.
FWIW, my sim was moved from a certified device when I got my One and for several months I had the VoLTE icon and it appeared to be working that way during calls. Eventually AT&T must have figured out I’d moved the SIM to an uncertified phone though, and it stopped working with VoLTE. That was about 6 months ago. Not a super huge deal, but of course it’ll become one next year if they stick to this schedule.
Any update on certifying T1 for AT&T? My cell provider sent an e-mail saying the are turning off my phone in a few weeks due to 3G. If the T2e is certified why not just switch out the T1 phones for a T2e phone.
Yeah AT&T said they were mailing me a new phone now, I’m wondering what the progress report on the Teracube 1 certification is now
I wish I could share some timelines on that. Its totally dependent on AT&T. However, we did make some progress last week.
@Tim_Hood @Gatlin_Newhouse - are you on Android 10 or Android 9? There is an issue with the APNs on Android 10 build because of which AT&T is giving 3G instead of LTE.
Android 10 but LTE is working for me
I’m on Android 9. Do I need to update to Android 10?
@Tim_Hood - you need not update to Android 10 yet.
Just got a notice that AT&T has shipped me a replacement for my Teracube One without me asking for it, an LG Expression Plus, which appears to be a much inferior phone on just about every spec. Yay?
Even if the One does stop working, I don’t see me using the model they’re sending me as the replacement.
