By the way, all seem to have security patch level “May 5, 2021” (which is of course old enough). Why does my 2e show an even older patch level (November 2020) while claiming to be up to date?
If you do not live near an EU country border, then you can install the SW16 update manually. EU users living near borders experienced a roaming issue due to which we had to recall the EU build.
Thanks for explaining.
But that was months ago, so you apparently made no further effort to fix this roaming issue after the recall.
I don’t permanently live at a border, but often enough by visit. So I unfortunately can’t consider installing this update. (But a buggy update that has to be installed the tricky manual way is honestly not my idea of decent support anyway.)
Thanks, my A11 update loaded without a hitch, now just waiting for security update, the one I just got is 5 October 21
Here still no update.
Edit: To be more precise: no automatically offered update.
Unfortunately, I can’t install the linked Andoid 11 upgrade because then the hotspot function (which is indispensable for me) allegedly won’t work anymore.
Agreed. We are waiting to fix FM for the automatic update (OTA) which is proving to be tricky.
Hotspot fix should come in the next update.
Two weeks shy of a year since the last security update.
This is ridiculous. I posted my concerns about the lack of security updates 2 months ago and have been patiently waiting for an update.
Android 11 was released recently for the first batch of 2e’s but it’s not without issues. Not to mention that apparently A11 doesn’t have the latest security updates either.
Can someone please update me on when a new security patch will be released?
Hi @Maiku - we are working on both fronts - fixing the reported issues and a new security update (will follow on heals of April 2022 update for T2e 2nd batch).
Hi Sharad, any news about the EU update?
Hi @Quax - the [Certified] Android 11 for Teracube 2e 1st batch (SN: 2020) is applicable for EU users as well.
I have noted that the Android 11 updates are full of issues.
Even with the latest 11.0.2 update, I am reading posts of users switching to a different phone.
I want to keep using my Teracube 2e as my primary device. As such, I choose to remain on Android 10 for the time being.
Is there any chance of providing the latest security updates for Android 10? I want to be able to have a secure, fully functioning phone for years to come.
Many thanks.
The lack of timely security patches means that I cannot use the teracube 2e for anything other than media consumption. I do not feel comfortable doing anything that involves financial accounts or purchasing goods and services online. I understand how difficult it is for a small phone company to update software. Even the mammoth companies such as Samsung, Apple, and Google constantly have to issue updates to fix bugs or zero day exploits.
Hi @Maiku, the 11.0.2 update is quite stable and has a similar performance as Android 10. The performance is the biggest improvement since the original Android 11.0 update. I have been using it as my primary device for quite some time now.
I’ll suggest you give it a try. In the worst case, you can always go back using SP Flash.
